Eaglefiler does not start
Hello,
after the update Egalefiler doesn’t start any more. Only the icon is show in the menubar, but nothing more happens. Already uninstalled and reinstalled it again. The only change i made was purchasing the a license and activating it. Great stuff.
Any recommendations how to bring Eaglefiler back to life again?
Thank you for your support in advance.
Which update are you referring to? EagleFiler? macOS? Which versions are you using?
There is no EagleFiler menu bar icon. Do you mean the Dock?
Are you able to see the EagleFiler menu next to the Apple menu?
I think there’s something else going on on your Mac, because the only thing that does is save your serial number in the preferences file. Please check for any errors reported in Console.
