I’m trying to file some individual emails in EagleFiler from MailMate. Using the MailMate bundle works well and is fast, but I want the option to drop an email directly to a folder in EF. I’ve noticed that either drag-and-dropping a file into the Drop Pad or into the EF window make EF beachball.
After reading the manual it seems like drag-and-dropping is a possible way to import mail from MailMate, and I prefer it because the MailMate bundle doesn’t allow for import options or selecting a specific library if several are open, so it isn’t ideal.
Thanks. It looks like macOS is hanging when EagleFiler asks it what you dragged. It seems to be waiting on another process. It may help to restart your Mac or to drag and drop to a Finder window for one of EagleFiler’s folders.
Rebooting didn’t help. Dragging to a EagleFiler Finder folder window does work to import, but it continues to freeze if I drag the same message directly to EF.
Which version of macOS are you using? Dragging from MailMate to EagleFiler used to work fine for me, but when I just tried it on 13.5, MailMate immediately reported an internal error. Then EagleFiler hung. After I dismissed the error, I waited a minute or so, and EagleFiler unfroze and completed the import.
There is a newer drag API that EagleFiler could use, which would likely prevent the temporary freeze, but EagleFiler doesn’t currently use that because it doesn’t work properly when receiving drags from Apple Mail.
I’m on 13.5 as well. I don’t see a report of an internal error from MailMate (I’m running 1.14 - 5937, which is a beta release), just EagleFiler hanging.
Aside from the other workarounds that I mentioned, you could possibly adapt the script in the MailMate bundle so that it brings up the EagleFiler options window.
I will try to find a better workaround, e.g. a way to tell EagleFiler to use a different code path when receiving drags from MailMate.
