EagleFiler holds on to application control
When I’m working in EagleFiler, sometimes when I try to move the focus to another open application window, control isn’t moved to the other application. Mouse clicks do nothing. I can still use the mouse inside EagleFiler windows. I have to close EagleFiler to be able to switch to other apps.
I’ve not heard of this happening before. It sounds like a macOS issue, since EagleFiler has no control over mouse clicks or other apps. Which versions of macOS and EagleFiler are you using? Does it help if you restart your Mac in safe mode?
I’m using macOS Tahoe 26.3 (25D125) and EagleFiler 1.9.19. I haven’t had a chance to check safe mode yet. One thought, could it be related to a library that is saved as a sparsebundle? Unfortunately it’s not repeatable but I first noticed it maybe 4 or 5 weeks ago.
I think this is fixed in the current beta.
I can confirm that I’ve had no recurrence of the problem using the beta.
