Easier Folder Management?
Is there an easy way to move folders around without having to drag and drop scrolling through long folder lists? I’d give my kingdom for a MOVE command that would enable me to select a location. Thanks for any guidance.
UPDATE: Found it. MOVE TO in RECORD menu. :roll_eyes:
But it is very PAINFUL. I found it impossible to navigate that giant scrolling expanded folder list. :frowning:
I have some ideas for improving this in a future version, but for now you may find it helpful to navigate the folder list by typing the first few letters of a folder’s name.
You can also open up multiple windows and use the search field to help locate the destination folder.
Thanks Michael. Perhaps just opening a finder dialog to move files would be cool. :pray:
