EF and Endo - error
Hi,
I read about the integration between EF and Endo. Just downloaded the latest version of endo, installed, and when I captured an article off endo with F1, the following popup appeared:
Applescript error
EagleFiler encountered an AppleScript error while trying to capture from endo.
The variable theArticle is not defined. (line 5)
Sorry, there’s a bug in the error reporting, but that error probably means that you didn’t have an article selected.
A bit off-topic, but …
Thanks for the reminder to pay closer attention to a similar error I’ve occasionally seen when invoking the “Add news to DEVONthink” script from NetNewsWire even when an article is selected. Then I’d be curious to know if the NNW to EF capture script properly handles the same article.
