Email from yandex.ru
I get spam every day from yandex.ru that I have to manually train as spam. Does SpamSieve recognize the asterisk variable in a rule so I can delete everything from *.yandex.ru?
If you keep having to train the same type of messages, that may indicate some sort of setup or training problem. Please see this page.
You could either create an Ends with rule without using an asterisk or create a Matches Regex rule that uses .* or other regex syntax.
Thank you. I have created a “ends with” rule.
Just to clarify, every email from yandex.ru is slightly different, which is why I had to manually train. The ends with rule has solved this issue. Thank you.
I’m glad the rule helped. Still, if the e-mails were only slightly different and all from the same source, not catching them automatically does probably indicate some other problem, which is why I recommended the other troubleshooting steps.
