Entourage 2008 error
Hi;
Been having issues with the move if spam applescript. It is moving it into a junkmail folder, but I still get an error -2702 from Entourage (error is attached). I tried reinstalling the scripts, and also recreated the rules. Appreciate any insight.
thanks;
John
What happens if you select the message mentioned in the error and choose “SpamSieve - Move If Spam” from the script menu (run the script; don’t apply the rule)?
Also, it might help to rebuild Entourage’s database.
Thanks for the reply. I ended up deleting all of the scripts and re-installed them again. That did the trick.
