Entourage freezes after Spamsieve update
Entourage was working fine until the update. After update Entourage freezes and Spam Sieve does not appear to auto launch. Tried deleting Spam Sieve and launching Entourage with the same results.
Any help or suggestions will be appreciated.
10.4.10 on a MacBook Pro 2.33 C2D
Thanks
SpamSieve’s integration with Entourage hasn’t changed, and you said that the problem still occurs after deleting SpamSieve, so it doesn’t seem like SpamSieve itself is the problem. It would be helpful if you could open the Activity Monitor program and select Entourage in the list. When it hangs, choose Sample Process from the View menu. Then save the resulting data to a file and send it to me.
Running some system maintenance and repairing permissions seemed to fix the problem. I re-installed Spam Sieve and it works fine now.
Sorry to bother you, thanks for the help.
Pat
