I am running SpamSieve v2.5 with Entourage V11.3.3. After I shut down and restart I find that I my aEntourage ddress book is gone. I looked on Mactopia and found a thread describing a similar problem.
I looks like there could be a problem with the “Synchronize contacts with
Address Book and .Mac is checked” instructions with SpamSieve. This is the posted answer, but it is not the solution:
“Do you have Sync Services selected? Depending on your settings if the Apple
Address Book is empty then Entourage would then sync with the AB deleting
all entries”.
I do not use the .Mac mail (Apple Address Book) . If this is indeed true, Then am I losing my Entourage Address book every time I start up? Does anybody know how I might recover my address book? This is getting really serious. Any and all help would be very much appreciated
Thank you
Clay Taft
