I have set up an EF library with a few hundred entries. So far, so good. Closed it, then copied a handful of *.pdf into a newly created directory. When I reopen the library there is an error:
Console entry:
08.09.14 22:33:39,524 EagleFiler[30932] appcontroller.pyc:406 Error opening library: <NSError Domain=com.c-command.EagleFiler Code=0 UserInfo={
NSLocalizedDescription = “TypeError: string indices must be integers”;
The .eflibrary is named <<Tommy EF Documents 2>>
Could anybody give me some advice on that, please?
Also, if you could e-mail me a ZIP archive of your old .eflibrary file, that would be helpful in investigating the source of this error so that I can try to prevent it from happening again.
Thanks. It looks like a non-crucial file was damaged, but for some reason the OS didn’t complain when reading it. If you just open the package and delete the .eflibrary/State.plist file, I think the library will open.
