Errors in update 1.4.13
After updating EF with version 1.4.13, I look the following message box just with opening the library.
An unexpected error has occured
(ValueError: NSInvalidArgumentException -***-
[NSMenu removeAllItems]: unrecognized selector
sent to instance 0x25d0cc0)
This message always appears when opening window at first time and disappears at next relaunching & opening.
Now, any trouble might be seen now about function of EF, and any collapse of current data.
More details are :
  1. Click EF Icon in Dock.
  2. Click Icon and select one of libraries after icon has DOT around bottom line.
  3. Error box appears.
  4. Click Continue button, then we have no window.
  5. Click Icon and select library again, then library window is open as usual.
To disable all the Folder Action, Hot Corner settings, and shortcut key function might not affect this situation.
regards,
From what I’ve seen, this error only occurs on Mac OS X 10.4 and 10.5. I accidentally introduced it while working around a bug in Mac OS X 10.6. It’s just a cosmetic bug. Once open, the library should function normally, and your data will remain intact. I will be issuing a fix shortly.
Thank you for kind action as always.
Exactly !!
As you say, my iMac’s OS is 10.5.8 and I can use EF normally after re-open library.
I cannot find any collapse in current database.
regards,
This is fixed in EagleFiler 1.4.14.
EF returns its position with my life perfectly.
It seems to look like in a more brisk way than ever.
Sincerely thank you for your wonderful effort.
regards,
