eudora rules
After upgrading to leopard I had a bunch or problems with mail. I do not think it was Spamsieve but I had a number of things installed like act on and other scripts.
I did a clean in stall of leopard and then reinstalled spam sieve. My mail problem is fixed but I do not think Spamsieve is working correctly. It does not move mail to spam and also there is no spam sieve rule under mail settings.
How do I completely uninstall and reinstall spam sieve?
Regards, David
Your subject mentions Eudora, but the body of your post suggests you’re using Apple Mail. Which is it?
  1. Uninstall
  2. Install
  3. Setup Mail
  4. Train
