Is there a way to view EverNote notes from EF? Each EN note has a corresponding file. Dropping the file into EF and then opening it opens EN but not the specific note to which the file corresponds (opening it from its regular location does open the note).
I don’t know if there is a way to “trick” an EV note to open the note it EN. Is there is a way to designate an exiting directory as an EF library (so that files in the directory appear in EF? If EN does not freak out if there are other files/folders in the designated folder that holds EN records there could be one place that had EN notes and EF files.
Daniel.
