EXPORT / IMPORT Block/White Lists
Is there a way to export and import BLOCK/WHITE lists…
OR
WHERE (what is the filename) are these stored?
I recently had to rebuild my iMac (disk crash). Was able to backup 99% of the data and files - so I still have access to my previous files… but I also have SpamSieve running on my laptop - which also has a block/white list that I could export/import - if I knew how.
After quitting both copies of SpamSieve, you can just copy the file:
/Users/<username>/Library/Application Support/SpamSieve/Rules
EXCELLENT! Worked like a charm! Thanks!
