F1 folder Option input
Hello Michael,
I love the f1 option. However, is there a way to collapse the folders within this option? I imported some old folders that have a lot of nested folders and so the folder list is really long and somewhat unwieldy. It would be great to nest the lower level ones into the upper level folders.
John
Not at present, but I’ll look into it. Maybe it can be an option or something. You may prefer to use type-select (just begin typing the name of the folder while the menu is open) to quickly find the folder that you want. This is actually the reason I chose not to show each folder in a submenu—the hidden folders wouldn’t be type-selectable.
