I would find it helpful to be able to be able to cycle back and forth through recently viewed records. More ambitiously, a history that lives in separate window or pane would be outstanding.
Thanks for the suggestions. I’m planning to add some history features. Meanwhile, one alternative for easily cycling back and forth is to open multiple windows. Then you can flip back and forth using Command- or Command-Shift- or by using Exposé.
