I find myself creating smart folders very often, both for permanent, as well as temporary purposes. I am looking for a quicker and easier intuitive way of creating smart folders quickly.
While the logic for some smart folders can be complex, often the criteria is a single tag, or a group of Tags with an AND between them. If I could select a tag (say from the list I get when clicking on the Tags Inspector), and then drag the tag unto the Search For area, and then have a smart folder generated based on whether a particular EF record has that tag, it would save me a great deal of time. Here is how the functionality would make sense to me:
- Dragging a tag to the Search For area will create a smart folder at the root level of the Search Area
- Dragging a tag unto a folder in the Search For area will create a smart folder under that folder.
- Dragging a tag unto an existing smart folder will perfomr an “AND [tag]” to the definition of the smart folder.
Just an initial thought.
Daniel.
