Feature Request: more control interfaces
Hi,
I find it some kind of uncomfortable to use the training options that can be found under the “Mail” menu. Why do you not implement buttons for the menu bar and add controls to the the right click menu?
JaTo
Have you tried the keyboard shortcuts: Command-Control-S and Command-Control-G?
I’m working on adding the commands to the contextual menu. I’m a bit wary that adding toolbar buttons might cause problems due to the way the SpamSieve plug-in would have to modify Mail, but I’m considering it.
Hi,
thank you for your work. I will ty out the keyboard commands.
JaTo
