From C-Command Software Blog - SpamSieve 3.1
SpamSieve no longer triggers the “find devices on local networks” prompt on macOS 15.
Sorry, that’s not true. I just saw it (after the 15.4 update). SS 3.1.2.
Thanks for the report. It’s unclear what would be causing that (unless you’re trying to print). If anyone sees this alert, please record a sample while it’s up.
Yeah, I suspect this is a MacOS bug. This isn’t the only app that I’ve seen put up the alert after the 15.4 update.
