Is it possible to find duplicate files on my Mac using EagleFiler? I accidentally copied a few files to multiple locations.
You can use the Allow duplicate files in library option in the preferences. With that unchecked, when you import files into EagleFiler the ones that are already in the library will be skipped.
How about the existing files before import?
No, EagleFiler does not find duplicates among files outside its library.
Thanks for the update.
P.S EagleFiler is a great app for file management. For duplicate remover, I found this post is quite helpful
