Finding if BBAutoComplete is installed and removing all traces of it.
I don’t remember ever installing BBAutoComplete, but for some strange reason < download.CNET.com > keeps sending me updates available notices for BBAutoComplete.
How do I find if BBAutoComplete and any of its components is actually installed and then remove all traces of BBAutoComplete’s parts?
I do have TextWrangler installed but I don’t use it and I am planning on uninstalling it after hearing from you. Will uninstalling TextWrangler remove all traces of BBAutoComplete?
[Mid2010 MacBook Pro, MacOS 10.9.5]
The main items are:
/Applications/BBAutoComplete.app
/Users/<username>/Library/Application Support/BBAutoComplete
/Users/<username>/Library/Preferences/com.c-command.BBAutoComplete.plist
There may also be BBAutoComplete scripts in the folder:
/Users/<username>/Library/Application Support/TextWrangler/Scripts
