Fun bug: infinitely receding PDF
I had a fun bug that just happened to me: I was looking at a PDF, and by default I have “continuous” turned of. However it was too small so I hit the “zoom in” button. Then at every interaction (moving the mouse, for instance), the PDF started getting smaller. This kept happening even if I right clicked and chose “continuous”.
Now it’s happening with all my PDFs without changing anything (as if they all shared the same zoom setting).
Quitting and relauching did not help.
Thanks for the report. I think this is caused by a bug in Quartz, but I will work around it. In the meantime, using Zoom To Fit should stop the zooming out.
I believe this is fixed in EagleFiler 1.1.2.
It is, thanks.
