I’m currently evaluating EagleFiler and it looks like a great balance between functionality and simplicity. I did have one question though. My primary use case is going to be quickly saving snippets of text, and the Command-% shortcut is currently the main way I get data in. One issue with this is that the record is given the entire name of the snippet, with the same for the title. My question is: is there an easy way (through built-in functionality, scripting or automator) to allow for the setting of a title / filename to be created for the snippet at the time it is created? (Tags would be nice too, but aren’t so important!)
I’ve put together a simple Automator workflow that simulates what I need by prompting for a filename and saving the selected text to the “To Import” folder, but it obviously takes a while for this to be processed, compared to the immediacy of Command-%, and it seems silly to duplicate the effort.
That’s great! Thanks for the quick response too. Checked your upgrade policy too and that is also very generous, so looks like I am soon to be a happy customer
