Glitches / error messages when importing mail from Outlook
When I use the capture command (option-fn-f1, for me), I get the following error message, whether I select messages as a group or a mailbox alone:
*EagleFiler encountered an AppleScript error while trying to capture from Microsoft Outlook.
The variable _gSkipAllEmptyMessages is not defined. (line 0)*
When I drag and drop messages, I notice that some make it into the library but others preserve only the recipient, sender, subject line --but no content.
This is a known bug that occurs when EagleFiler encounters an empty message in Outlook. If you contact me via e-mail I can send you a pre-release version that fixes it.
Were these messages imported from Windows Outlook? I’ve seen an Outlook bug where it’s unable to export the content of some such messages.
I’ll send my email. No, these weren’t imported from Windows Outook. The pattern for the drag and drop problem seems to be that the first message in a folder is captured, in toto, and the rest are blank in the body of the message.
This is fixed in EagleFiler 1.6.4.
