Good emails being disregarded as trash
Hello,
I am using SpamSieve as follows:
I have all of the domains I want to pass as good in the Allowlist. Usually “ends with…” then domain.
The blocklist simply contains the “@” text to match, since the program will check that after the allowlist.
This means that I only want known emails domains to pass into the inbox. Al of the rest are junk (or trash).
Here is the issue:
The same 3 sets of emails are consistently sent to the trash. All of the rest work fine. When I re-add these addresses to the Allowlist (this time as fill address rather than domain only), they still get sent to the trash a few minutes later.
Is there a way to tell why it is sending only these particular emails to the trash?
I have seen some changes in behavior recently, also, where more email is being sent to the Junk folder, rather than Trash.
I think I have all other options turned off.
Thank you in advance.
Mark
Both of these sound like it’s some other filter (e.g. on your mail server) moving the messages to Junk. If it was SpamSieve, the Log window will say what it did and why. There’s also more troubleshooting information here.
Thanks for the quick reply. I was looking for that Log window!
Turned out as you stated, there was another program running on another computer, that auto-started itself.
Thanks again!
