Google, OneDrive, or iCloud Drive
so I have my library main folder in icloud. I have always setup a zapier that writes all my google events as they are created into a seperate file onto onedrive.
I am looking for a way for EF to sync this folder on onedrive to my EF system so when new events are created I will see them in EF. I tried doing this but EF says it cannot access onedrive it doesn’t have permissions.
I can use google drive, onedrive, or dropbox.
Zapier doesn’t zap to icloud.
Thanks
There’s information about the different cloud storage services here. I generally recommend Dropbox.
That said, I wouldn’t expect there to be any permissions problems importing from another folder. Have you looked into the permissions on the files/folders in question? How were you sending those files to EagleFiler?
