Great Software and a Quick Question
Hi Michael,
Loving the SpamSieve trial and it is collecting with ease all the spam I used to receive and placing it into my designated spam folders/mailboxes for disposal. I am using it on one computer as a Drone and it is all working well. I am just off to purchase a registration.
Just a quick question; I presume I can create any mailbox/folder and call it whatever I wish to collect the spam - provided of course I adjust the rule settings ? Fastmail already has a folder called spam so I need to have another folder called something else. Hopefully no problem ?
Best regards,
Stephen
Yes, and you should also change the name using the Change Settings command.
