Green Contents Button
Hello,
I clicked on the Green Contents Button, and not sure what I did. I do not seem to find a reference for its purpose. What does it do, and does it un-click? tia
pelone
That button corresponds to the Contents of Record menu command. Basically, it takes you down a level (downward pointing triangle) and opens a folder or mailbox in the same window. The opposite command is Enclosing Record (the other green button, upward pointing triangle), which takes you up a level to the parent folder.
re:Green Contents Button
Hello,
Thanks, I only had a few entries added so that is likely why I did not see anything change. It makes sense now, thanks for the reply.
Thank you too for a great program! It is so elegant, it almost works as if it were written for me. Not too often any of us come across a program of this calibre!
pelone
