Hang When Updating to SpamSieve 3.2 on macOS 15.3.1
I’m running Sequoia 15.3.1. When I try to install Spamsieve 3.2, it hangs. I’ve tried installing it directly from the email I received announcing the upgrade, and directly from the downloads folder. Even sent the old version to Trash and tried to reinstall a fresh download from your website. Same thing - it hangs. Any solution you’d suggest? Thanks!
At what point is it hanging? Do you mean when when you were copying the file in Finder or when you go launch the new version or at some point after that?
In general, if SpamSieve is hanging, please record a sample log.
And… after going through the rigamarole described aabove, I see Spamssieve listed in my Applications folder and the version is… 3.2. I’m curious about what caused installation to appear to hang, but no need to satisfy my curiosity unless you can do so without effort.
It’s unclear to me what happened. We have no other reports of hangs during update/installation. I’m glad that the problem at least seems to be resolved now.
