Users: I am in search of help with a line of script that would create a series of nested folders within one Library.
I need:
- Year (beginning 1850) [YYYY] through 2021
- Months YYYY-01 through YYYY-12 (for each year - nested)
- Days for each month YYYY-MM-DD for each month (nested)
I also would need instruction about how to insert said script in the Terminal Command line (or other location) on Mac using Mojave through Big Sur.
It is my hope that this would be a very simple task for a user more advanced than I and express my sincere appreciation in advance.
Steve
Here’s a script that shows how to do this:
use framework "Foundation"
set _calendar to my NSCalendar's currentCalendar
set _startComponents to my NSDateComponents's alloc's init
_startComponents's setYear:1850
_startComponents's setMonth:1
_startComponents's setDay:1
set _startDate to _calendar's dateFromComponents:_startComponents
set _endComponents to my NSDateComponents's alloc's init
_endComponents's setYear:2021
_endComponents's setMonth:12
_endComponents's setDay:31
set _endDate to _calendar's dateFromComponents:_endComponents
set _dayComponents to my NSDateComponents's alloc's init
_dayComponents's setDay:1
set _yearFormatter to my makeFormatter("yyyy")
set _monthFormatter to my makeFormatter("yyyy-MM")
set _dayFormatter to my makeFormatter("yyyy-MM-dd")
set _date to _startDate
repeat until (_date's compare:_endDate) is my NSOrderedDescending
tell application "EagleFiler"
tell library document 1
set _yearFolder to my ensureFolder(root folder, my format(_yearFormatter, _date))
set _monthFolder to my ensureFolder(_yearFolder, my format(_monthFormatter, _date))
set _dayFolder to my ensureFolder(_monthFolder, my format(_dayFormatter, _date))
end tell
end tell
set _date to _calendar's dateByAddingComponents:_dayComponents toDate:_date options:0
end repeat
on makeFormatter(_format)
set _locale to my (NSLocale's localeWithLocaleIdentifier:"en_US_POSIX")
set _formatter to my NSDateFormatter's alloc's init
set _formatter's dateFormat to _format
return _formatter
end makeFormatter
on format(_formatter, _date)
set _nsString to _formatter's stringFromDate:_date
return _nsString as Unicode text -- Only works on a separate line
end format
on ensureFolder(_parentRecord, _name)
try
return first library record of _parentRecord whose name is _name
on error
tell _parentRecord's library document
return add folder name _name container _parentRecord
end tell
end try
end tell
end ensureFolder
Do you need to run it from Terminal? Or can you just copy/paste it into the Script Editor app and run it once?
I just found this, Michael. Thank you very much. I don’t know whether to do it from Script Editor or Terminal (makes no difference to me) but I will ask a friend to help. You are very kind!
It would probably be easiest to copy and paste it into a new window in Script Editor and then click Run.
I got it to run and it’s creating the folders now for me. Thanks a million, Michael. Very much appreciate your help.
Steve
Michael, I completed the task but with lots of hangs and restarts. I suspect it’s because a new library is being created for each day. Tried turning off indexing and meta-data indexing per manual instructions but still v-e-r-y slow. Can you please modify (or tell me how to modify) the script so that I end up with only years and months. I will then just insert entries with a date stamp or identifier into the correct month. Sorry for any trouble. Thank you. Steve.
It would be helpful if you could record some samples during the hang.
It’s just creating a new folder, not a new library.
It may simply be that there is overhead in having and displaying so many folders in the source list and updating that each time a folder is added. You could try collapsing the Library portion of the source list until the script is done.
You could delete the line that begins with set _dayFolder.
