Hi,
I think that allowing to change folders order will increase organization and it´s a basic need for many people.
After all of this years of this good organizer I do not see the possibility to manually change folders positions.
Is there or will it come any feature like this ?
I think that Eaglefiler uses the correct method to organize files because it keeps then in a natural directory structure but there “new kids in town” and I am comparing the features to allow better organization.
Thanks you all.
Currently, you can do that by renaming the folders, e.g. adding spaces, numbers, or punctuation so that they sort to the top or bottom of the list. I agree that it would be good to be able to reorder using drag and drop.
