How to change name of library?
I want to change the name of an Eaglefiler library. How do I do that? Do I change the name of the folder in the Finder? Or is there another way to do that?
Frank
So long as the library is not currently open in EagleFiler, you can use the Finder to change the name of the library folder and/or the .eflibrary file.
