How to Continue using Command-6 to go to Junk Mail
Hi,
I think i remember reading somewhere in the manual that you can leave the apple mail junk filter on in a way that allows you to continue having the junk mail box use the junk icon and also have the command-6 shortcut work. I think you need to set up the rule for junk mail in the apple mail junk filtering preference to something that will never happen. I just cant remember. Could somebody point me to where this is discussed in the manual or online help? I just can’t find it.
Thanks
Yes, that’s the idea; please see this page.
This trick no longer works in 10.5? I can setup the custom action but cannot get to the junk mailbox by way of Apple-6.
Yes, Apple has confirmed to me that this is a bug in Mail.
