Hello!
While using EagleFiler Hazel imported a file into the (opened) EagleFiler-database.
However the new file didn’t showed up until I restarted EagleFiler.
Is there a way to force EagleFiler to refresh whitout restarting?
Thanks!
Regards,
Vlad
Hello!
Thanks!
Regards,
Vlad
Yes, you can use the Scan for New Files command (or perhaps have Hazel run a script that invokes it automatically after adding the files).
