How to use SpamSieve with EmClient
  • MacOS 15.4.1
  • SpamSieve 3.1.2 with licence. Running.
  • eM Client 10.3 with licence. Running.
  • AppleMail should never be active.
There is no supported way to connect SpamSieve and eM Client.
I made a Python script to connect to the email server.
mail = imaplib.IMAP4_SSL(SMTP_SERVER)
After some steps I can give SpamSieve one email to check.
r = requests.post(“http://localhost:2000/spamsieve”, data={“message”: raw_email})
Unfortunately, SpamSieve does not start an HTTP server.
defaults write com.c-command.SpamSieve AllowRemoteControl -bool true doesn’t help.
How to start the server? How to connect to it?
Is there another API?
SpamSieve does not have an HTTP API on that port, nor an AllowRemoteControl setting. I’m not sure where you found those…
However, it does have an AppleScript API. You could do something like this:
import subprocess, tempfile, os
# Fill these in with info from your IMAP server
sourceBytes = b""
accountName = "MyAccountName"
mailboxName = "MyMailboxName"
# Message may be larger than the argument or environment limit, and there's seemingly no way to pass to AppleScript via stdin these days, so write a temporary file
fd, path = tempfile.mkstemp(".eml", "MessageForSpamSieve")
with os.fdopen(fd, "wb") as file:
    file.write(sourceBytes)
appleScript = """
on run _argv
    set {_path, _accountName, _mailboxName} to _argv
    -- Read without encoding so the "string" gets passed to SpamSieve without changing the bytes
    set _file to open for access _path
    set _source to read _file
    close access _file
    tell application "SpamSieve"
        -- Change to true if you will be correcting mistakes, either via another script or SpamSieve’s Log window
        set _autoTraining to false
        set _origin to {source identifier:"com.yourdomain.imap-script"}
        set _origin to _origin & {application name:"YourScriptName"}
        set _origin to _origin & {application version:"1.0"}
        set _origin to _origin & {mail account type:"IMAP"}
        set _origin to _origin & {mail account name:_accountName}
        set _origin to _origin & {mailbox name:_mailboxName}
        set _score to score message _source auto training _autoTraining origin _origin
        return _score
    end tell
end run
args = [
    "/usr/bin/osascript",
    "-e", appleScript,
    path,
    accountName,
    mailboxName
completedProcess = subprocess.run(args, capture_output=True)
if completedProcess.returncode == 0:
    scoreBytes = completedProcess.stdout
    score = int(str(scoreBytes, "utf-8"))
    if score >= 50:
        print("Message is spam")
    else:
        print("Message is good")
else:
    print("Error:", completedProcess.stderr)
os.remove(path)
When I first bought this I was using new outlook (2 years ago?). I knew that wouldn’t last because new outlook kind of blows. We used spamsieve with apple Mail and let it sync. But I thought emclient was supported. Anyway, I switched to emc because I knew it supported applescript but I am not prepared to do the implementation myself. I have too much on my plate now. Any chance this is in the works? Or am I still stuck with this clunky 2 mail client approach?
Legacy Outlook still works.
eM Client doesn’t have any meaningful support for AppleScript or any other suitable extension mechanism, as far I can see.
OK. Thank you, MIchael. Legacy outlook is doomed and microsoft has turned the editor into fluff. It used to be word and was strong. No more outlook for me after 30 years
