I lost whitelist, corpus etc
After a “cleaning” job on my iMac I have been asked for input of my Spamsieve registration - which already made me suspicious -but it went fine.
Since then my Whitelist, Corpus and all are back to their virgin state, as if I were totally new to Spamsieve.
As I am another very happy user, I would love to get my collections back.
Where do I look? Where is it usually located?
Many thanks!!
Pol in Luxembourg
It sounds like your “cleaning” deleted the preferences file:
/Users/<username>/Library/Preferences/com.c-command.SpamSieve.plist
and the folder that stores all of SpamSieve’s training data:
/Users/<username>/Library/Application Support/SpamSieve/
Found an old copy, but
I have found an old copy on an external back-up disk with 32 Kb.
I have replaced the new com.c-command.Spamsieve.plist (with 4 Kb), but it keeps changing back to the “new”= virtually empty one.
  • I also trashed the new one first and then (with SpamSieve off) pulled over the back-up version(32 Kb) - and yet the same.
  • I also Copied and posted the content of old (32Kb version) into the new one - still no success!
Any suggestion, before I decide to give up and build it all up again.
Thanks anyway for a great product!
Pol
You should only replace the preferences file when SpamSieve isn’t running. If you still can’t get it to work, please e-mail me the two preferences files.
