Dear forum,
how will Entourage 2004 learn to move spam from the IMAP-Junk-folder automatically?
None of the solutions here is working.
My idea: After logging out, spam will delete. At this time I have to do this manually.
Regards
Kara
Dear forum,
Regards
Kara
Are you asking about moving spam to the Junk E-mail folder or from it (to where)? The Entourage setup instructions show how to make SpamSieve move incoming spam messages to the Junk E-mail folder. To automatically delete messages from the Junk E-mail folder you could create a schedule in Entourage.
Dear Michael,
no, I’m asking to delete spam automatically from the Junk-E-mail folder (IMAP). In my Entourage 2004 I have no opportunity to create a schedule that works with IMAP folders. This was my first idea too. Maybe you know a solution. Deleting POP is no problem - but schedules will not work with IMAP. Am I wrong?
Regards
Kara
It looks like you’re right. Entourage 2008 also does not support this for IMAP folders. However, you could modify your SpamSieve rule to put the messages in a local folder.
You’re hint might be working. Thank you! I can’t understand why this feature is implemented only for POP - mystic.
Regards and a good time
Kara
Edit: It works perfect! ![]()
