Import Tags from Tagit or Tags Application
I have used the Tagit App or Tags App to tag my files. As they do not store the tags in the comment field, EagleFiler does not import them. I treid all the import scripts and special options from the manual, but my Tags are not imported.
tagit is freeware and you can try it easy with one file.
Please help me to make the switch to EagleFiler.
Thanks in advance, Frank
Those applications are saving their tags in a location that EagleFiler doesn’t know about. So, at present, you would need to tell EagleFiler about the tags, e.g. by putting them in the Spotlight comments or via AppleScript.
EagleFiler 1.4.5 imports tags from these applications.
