Hello,
I am a new user and am trying to import bookmarks.
As per my current understanding, I expect importing an HTML file created by Safari, Firefox or Zotero should be parsed and that every url found will generate a record in the format configured (bookmarks, html, pdf, …).
Is that correct?
If so:
I have tried drag/drop into the main window, the Drop Pad and the “To Import” folder.
I enabled “allow duplicates” to be sure that was not my problem.
The input HTML file gets loaded into the library as is, no parsing/retrieving of each url.
Is that the expected behavior or is there some configuration option I am missing?
Regards,
Philippe
