Importing from Camino
When I use the capture key to import from Camino it always imports the first tab. That’s fine if it’s the one I want, but if I’m looking at the third tab I want to import that one, not the first! Using this version of Camino: Version 1.6b3pre (1.8.1.13pre 2008021201) and the latest version of EagleFiler.
Regards
Dave
Unfortunately, I don’t think Camino allows other applications to see which tab is active.
EagleFiler 1.4 can now capture from the correct Camino tab.
