If I’m reading this correctly it’s not a big deal and I could just choose “Continue” and everything would be fine moving forward with filtering, but I’m not 100% sure and wanted to check. If I’m wrong and this is something I need to deal with, do you have thoughts about how I can do that?
Right, it’s not a big deal. It’s just letting you know that the old accuracy statistics and log info won’t be visible in SpamSieve 3, but it doesn’t affect the filtering. You can just click Continue and it will proceed with importing everything else. Or you could click Cancel if you have access to a backup of that file that you could restore and then try the import again.
