Importing Outlook 2011 from files
Hi - My Outlook identity is corrupted. Is there a way to import email directly from the identity files into EagleFiler rather than within outlook? (As Outlook will no longer even open with that identity - and I’ve tried rebuilding it a few times now).
Any help appreciated.
Mark
Unfortunately not. The Outlook identify folder uses a proprietary format, and EagleFiler depends on Outlook to interpret it. It might help to rebuild your Outlook database.
