Hi,
Currently with my Sennheiser Momentum True Wireless earphones, I like to just put them in my charging case to disconnect, rather than manually disconnecting from my mac. This means that they automatically reconnect to my mac when I remove them from the case.
I was hoping that Toothfairy would help my earphones to switch to AAC when they connect, but it seems that the ‘Improve sound quality by disabling audio input’ only works when using Toothfairy to manually reconnect.
It’s not the end of the world, because I can just disconnect and reconnect using Toothfairy when I take them out of the case, and it’s still saving me some effort, but it would be really cool if that wasn’t necessary.
Is this expected behaviour, and would it be possible to request this as a feature?
If it’s not technically feasible, then I understand.
Thanks!
