Incompatible Plug-ins Disabled
Running MacBook Pro
OS 10.6.5
Mail 4.4 (1082)
SpamSieve 2.8.4
I keep getting this message.
Mail has disabled the following plug-ins:
SpamSieve
Contact the makers of these plug-ins for versions that are compatible with Mail 4.4 and Message 4.4.
No matter what I do, it seems to disable the plug-in. Any suggestions?
Patrick
The problem was that Xslimmer had been used, and it damaged SpamSieve’s plug-in so that Mail couldn’t load it. The solution is to download a fresh copy of SpamSieve and choose “Install Apple Mail Plug-In” from the SpamSieve menu.
