I’m a newbie to Eagle Filer, so pardon my ignorance. Two questions:
When I open EagleFiler, I do not have the option to open a particular library via the File > Open Library drop down menu - no libraries are listed. However, the Drop Pad box at the lower right corner of my screen has that option. Why?
I wanted to index text in pdf newspaper clippings so I ran one clipping through an OCR program with no effect. I then took another file, which was a jpg, converted it to pdf via an online service and then ran OCR on it, too. Neither file shows up in EagleFiler when I enter a keyword that is in the file. The only files EagleFiler finds are the files that existed before I imported this new file. Reindexing produces no results and Importing again gives me the message that the file is a duplicate and won’t be added. Where is this file and why doesn’t it appear in the keyword search results?
