Where do scripts get installed in Sequoia 15.3.1?
I do not have a folder called Eaglefiler in ~/Library/Scripts/Applications/
They should still go in ~/Library/Scripts/Applications/EagleFiler/. You will have to create the folder (or let the script menu do it for you) if it doesn’t already exist.
