I’m battling getting Apple emails imported into EagleFiler.
I select all messages in a particular folder, and press FN-1
Popup says 811 messages copied.
When I look at EagleFiler it says
error: MJTException - <NSError Domain=MJTErrorDomain Code=1002 UserInfo={
MJTCurrentUserName = “mdm”,
MJTFailingKey = “EagleFiler-2020-04-22-sAXFdCi3SHSiaG7ZXw-cwg”,
MJTFailingObject = (
“EagleFiler-2020-04-23-UZxsQyZrSOaKsTR7D7tnYA”
MJTFileExists = 0,
MJTFileIsLocked = 0,
MJTFileOwnerName = “unknown-name”,
MJTParentFolderACLString = “”,
MJTParentFolderIsLocked = 0,
MJTParentFolderModeString = “755”,
MJTParentFolderOwnerName = “mdm”,
MJTStackFrames = (
“-[MJTTempFolderManager tempFolderURLWithName:error:] (116)”,
“-[NSURL(MJTFiles) mjtCheckDirectoryExistsError:] (187)”
NSFilePath = “/Users/mdm/Dropbox/EagleFiler/mdm-email/mdm-email.eflibrary/Temporary Items.nobackup/iCloudDrive.nosync/EagleFiler-2020-04-22-sAXFdCi3SHSiaG7ZXw-cwg”,
NSLocalizedDescription = “The expected directory was not found.”
I’ve also tried saving those same messages (Raw Message Source) and then putting the file into the To Import folder. Worked the first time, but not subsequent times.
The file disappears from the To Import folder, but does not appear in the Eagle Filer Library. Nothing in Activity nor Errors windows. Can’t find a log file to see what happened.
How should I be trroubleshooting this ?
EagleFiler 1.8.13
Mac OS Mojave 10.14.6
Thanks
mark
