I’ve got over 15K rules in my blocklist and 48K in my allowlist and am wondering if I should try consolidating these rules. Does anyone else do this? I reckon that filtering might run faster?
I also have a ton of rules in each list that aren’t enabled. Is there any risk to deleting rules that aren’t enabled?
I think that would take you a lot of time and make the filtering slower.
Yes. The disabled rules are recording the fact that you don’t want that rule. If you delete it, when you train a message SpamSieve might end up recreating the unwanted rule in an enabled state.
SpamSieve ships with a small number of built-in blocklist rules. The first one is for matching spams with a certain type of inline image. The second one is included as disabled to prevent SpamSieve from auto-creating an unwanted rule when you train a message with a missing name.
