Is there a way to set the URL of a record afterwards?
I’ve added some entries using “Print”, then PDF and “Save PDF in EagleFiler” from Safari or another browser, on Mac or iOS, but the URL is not captured this way.
Is there a way to set the URL afterwards? The URL field seems to not be editable on the Info pane.
When save to PDF, the PDF is generated by macOS rather than EagleFiler, so it doesn’t have the opportunity to grab the URL. You can set Safari to include the URL as a footer in the PDF page, however.
The source URL is not directly editable in EagleFiler’s Info window, but it can be set using this script.
Great, thanks!
