Is there a way to whitelist entire domains temporarily?
Hi there,
I’ve been using SpamSieve for a few months now and loving the results overall — it’s catching 99% of the junk.
Quick question: Is there a way to whitelist an entire domain temporarily, like during a product launch or email campaign, so I don’t miss anything from a particular sender group (e.g., @partnercampaign.com)?
I know about adding rules, but I’d love a way to automate that with a time-based reset or easy toggle. Curious if anyone has a workflow or AppleScript workaround for that.
Thanks!
— Jhonn Mick
Say that you have an allowlist rule:
From (address) ends with @partnercampaign.com
You could you control it with an AppleScript like this:
tell application "SpamSieve"
	tell allowlist
		set rule "@partnercampaign.com"'s enabled to true
	end tell
end tell
Thanks, Michael, that’s exactly the kind of solution I was hoping for. I’ll give the AppleScript approach a try and see how it works in practice. Really appreciate the quick and clear guidance :pray:
